Aftermarket ignition.
Old 05-12-2018 | 03:36 PM
Fblo1690's Avatar
Fblo1690
Default Aftermarket ignition.
i am going to check my ignition timing.
My question is, is there any advantage to a different ignition module? Single fire vs dual fire? Or should I just check mine and ride on? I’ve researched all this and there’s no straight answer.
also from what I understand from manual is, start bike, while idling the light should light up when front cylinder advanced timing mark is centered in hole. If not,adjust accordingly.
1997 Evo. Mikuni 42 Carb. Screaming eagle exhaust slip ins.
Old 05-12-2018 | 04:16 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Yes there is. There are different rates that the module advances the timing (heavier bike, lighter bike. With OEM modules) Also there are differences in the rev limiter setting... As for the Single vs Dual, I really don't see any advantages...
To set the base timing you do not start the bike....
Put the front cylinder to TDC then rotate the module till the red light comes on then back it off just till it goes out.. Lock it down, your done.
Curve 2 should do you good....
Old 05-12-2018 | 04:46 PM
Fblo1690's Avatar
Fblo1690
SO until I get the after market ignition...how do I check my stock timing.
Old 05-12-2018 | 04:51 PM
98hotrodfatboy
with an inductive light and a clear lense where the plug goes. I usually turn it up till it pings when rolling the throttle at 2400 rpm 5th gear cruising and then back it off till it stops..... Good to go...
Old 05-12-2018 | 05:19 PM
Fblo1690's Avatar
Fblo1690
No tach
Old 05-12-2018 | 05:22 PM
Fblo1690's Avatar
Fblo1690
So I would let it idle and look for the front cylinder advanced mark?
Old 05-12-2018 | 05:51 PM
98hotrodfatboy
Your knocking yourself out with this. If you don't have a tach just do 50 in 5th and nail it if it pings turn it back. If it doesn't turn it up till it does then back it off a tad. It's not a precision race bike... Being all that close or a tad off isn't gonna make any difference...
Old 05-12-2018 | 05:55 PM
Fblo1690's Avatar
Fblo1690
Would “back” be rotating to left.
And i I guess I can leave the cover off and do that.
Old 05-12-2018 | 07:00 PM
98hotrodfatboy
Back is retard.... yes
Old 05-12-2018 | 07:33 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Do yourself a favor and get a Dynatek 2000p.
It's a plug in module that will make your bike start way easier than it does now.
Quick Reply: Aftermarket ignition.
