Re-sealing my gas tank
Old 05-21-2018, 01:18 PM
ClifWideGlide's Avatar
ClifWideGlide
ClifWideGlide is offline
Update so far. I’ve used the POR15 stripper that was included in the kit I purchased twice. First time I used some ball bearings inside to try and losses the sealer. It worked ok but I can see a lot of sealer still inside the tank thru the few openings I can look thru. So the second time I used the stripper I put in nuts and got a lot more sealer out but still have sealer in the tank. So far I haven’t messed up the paint but it was close! Now I’m thinking of using acetone for my third time or just say to heck with it and run it like it is! Any thoughts on acetone being any better then the POR15 stripper?
Old 05-21-2018, 02:46 PM
0maha's Avatar
0maha
0maha is offline
Received 4,681 Likes on 1,665 Posts
I doubt acetone will touch it.
Can't say I've tried it, though.
If you've got some, give it a shot. Can't hurt.
Old 05-25-2018, 08:13 AM
ClifWideGlide
Well to heck with it! I’ve tried the acetone and the POR15 stripper and no mater how well I think I’ve covered the paint and thought I had all openings sealed up tight, I always had seepage and the paint effected before I could get it wiped off. Lucky it didn’t remove the paint but I can see where it was starting too. I did get some of the sealer out but I would say only about 50%. I’m not taking anymore chances and will just have to check the petcock filter more often.
Old 05-25-2018, 10:05 AM
megawatt's Avatar
megawatt
megawatt is offline
On a 2003 FXDL a family member has the liner is falling off inside the fuel tank.
We have removed as much as we could and now just check the petcock screen if the bike starts acting up.
That stinking sealer is a PITA when it starts peeling.
I am with Omaha on this, I would not seal it unless it is leaking and you don't want to weld up the leak.
As suggested, keep the tank filled as much as possible or is convenient for you.
Old 05-25-2018, 12:01 PM
Yankee Dog's Avatar
Yankee Dog
Yankee Dog is offline
Received 2,101 Likes on 1,049 Posts
Let the paint that was affected by the acetone sit for about a month then use a little polishing compound. It only works on the dull finish, won't help the stuff that is lifting. YD
Old 05-25-2018, 07:32 PM
ClifWideGlide
Thanks for all the input and suggestions! I reinstalled the tank today and got my bike running and for now I don’t see anything floating or leaking anywhere.
Mohill
General Topics/Tech Tips
23
08-04-2019 09:57 AM
805dwg
12-29-2018 01:42 PM
kennylxix
09-23-2018 12:41 PM
kris0082
04-27-2014 06:53 AM
1200c
01-04-2006 11:53 AM
Quick Reply: Re-sealing my gas tank
