Clutch slippage after cam and ignition upgrade!!
I have an 89 FLHS with 25k that I recently had an indy install an EV27 cam and single fire ignition with lifters and pushrods. When I stepped on it from 3rd gear up the clutch slipped and I had to back off. It runs great but I can't live with this clutch and don't know if upgraded springs are needed or complete clutch assy. I had no previous problems with the clutch. Any thoughts or reccs?
I agree with the above. I used an EV27 and replacement ignition for many years without problems, using the stock clutch. Until recently I continued to use the stock clutch with only a stronger spring with my S&S 107". If adjusting it by the book doesn't fix it you may have to dismantle it along with the operating mechanism, to check things over.
flhsport (02-18-2018)
Also check the spring plate to make sure the rivets are still good and haven't come loose or fallen out.
R Joe - I had researched a lot of old threads on this topic and one guy said he had the same problem and adjuster was set on B and he switched it to C and his slipping stopped, so I gave it a shot and the first fifteen minute test drive it did not slip at all when I accelerated hard from a downshift to third or fourth!! It has been cold and wet here the last two weeks so I will test it out next week when it should be dry and in low 70's.
Frog Nuts - My indy charges $50 per hour and does great work. I had alot of work done, rear tire, EV27, twin tec single fire ignition and coil, oil/filter, reseal rocker boxes, for around $1300. I think the ignition/coil made the biggest difference but I haven't put 100 miles on it yet due to weather. I have a Super B carb that was choking and spitting sometimes when I accelerated quickly or cruising at lower speeds and that seems to have been eliminated also. Only an occasional spit back but nothing like before. Good luck
Frog Nuts (03-25-2018)
