Bassani customer serv is ____
Old 01-25-2018 | 09:18 PM
aces&8s's Avatar
aces&8s
Default Bassani customer serv is ____
Bassani exhaust some times come with the wrong exh bracket. Then took 3 weeks for them to send the 2nd bracket. After bolting everything up the 2nd bracket is 1.5" too short. Boxed up the $700 exh and sent back to the store. Too bad Bassani don't know there own product well enough to send a bracket that fits.
Attached Thumbnails Bassani customer serv is ____-d-18-too-short-bracket.jpg
Old 01-26-2018 | 01:57 PM
brad75raiders's Avatar
brad75raiders
What exhaust are you going to run?
Old 01-26-2018 | 04:57 PM
aces&8s's Avatar
aces&8s
For now I put the VH straight shots back on. As good as this engine runs at bottom end and top end I have no complaints. MHO, this engine does it all. It can throw you on your butt taking off, and fishtail going into 4th. Goes from 50 to 100 passing a car. At 9.8 compression, It never pings in the GA heat. Just don't see a need to spend on big money pipes.
Old 01-26-2018 | 06:56 PM
Ruggs59's Avatar
Ruggs59
I would have just drilled a new hole in the bracket if you really wanted that exhaust. Looks like there was plenty of room to do so. (I know it should fit the first time of course)
Old 01-26-2018 | 07:49 PM
aces&8s's Avatar
aces&8s
Not after what I went through to get the 2nd bracket. There was only enough room on the bracket to drill one hole and that's not much to hold the exh on. They would have only been bolted on the heads and one bolt on the exh. that would not be good enough for $700 exhaust.
Old 01-26-2018 | 08:03 PM
Ruggs59's Avatar
Ruggs59
you sir are correct, It would have vibrated and cracked soon
Old 01-26-2018 | 08:08 PM
aces&8s's Avatar
aces&8s
[QUOTE=Ruggs59;17033408]you sir are correct, It would have vibrated and cracked soon
Yes sir, or worse, the one bolt fall out going dn the highway could mess up a lot of money.
ABQ-Jammer
Exhaust System Topics
12-20-2018 04:29 PM
Umby
08-06-2013 07:12 PM
Deluxe Hillbilly
09-05-2012 01:39 PM
bpav16
08-22-2012 05:43 AM
Dax4800
03-08-2010 08:13 AM
Quick Reply: Bassani customer serv is ____
