James metal/silicone cam cover gasket question
hear is the skinny - in order to get the correct distance you need to torque the cover on with the gasket in place - some gaskets have a red splather on them - BUT if you remove it that becomes a broken seal for the cover < we stopped using it
we only use the paper OEM style and or the Cometic AMF - foam over thin alloy as that happens to seal real well and its re usable just like the paper
at times a moron has been using a hammer and screwdriver to remove a stuck cover and the foam is a great add for us in the shop as it form fits locations stupid people have been
the spec is .010 to .016 on the cam the 10 is always preferred
