Signal lights don't self cancel anymore.
Old 11-01-2017 | 11:56 AM
Hey Man's Avatar
Hey Man
Default Signal lights don't self cancel anymore.
WTF is this now all of a sudden. 1993 FLSTC and neither side shuts off automatically. Just started not doing it this morning. I tell ya these new-fangled motorcycles are a pain in the ****.
Old 11-01-2017 | 12:10 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Is your speedometer working?
The flashers cancel because of a white/green wire from the speedo to the flasher module.
There is a connector in that wire between the speedo and the module that you should check for corrosion if the speedo is working.
Old 11-01-2017 | 01:18 PM
WP50's Avatar
WP50
been there
What THC said to begin
WP
Old 11-01-2017 | 02:16 PM
Hey Man's Avatar
Hey Man
Son of a seaweed suckin' seacook sailin' south!!! As a matter of fact my speedo isn't working. I just noticed that this afternoon. Didn't see it in the morning at 5 am. Now I have to figure out if it's the speedometer or just the cable. I wonder what my chances are that it will be the cheaper one of the two.
Thanks THC.
Old 11-01-2017 | 02:41 PM
texashillcountry
Dirt don't hurt
Thanks THC.
Best bet is to check the cable first.
They are usually the first to go.
Old 11-01-2017 | 03:43 PM
grbrown's Avatar
grbrown
Talking
We're here for ya......
Old 11-01-2017 | 04:18 PM
Mattbastard's Avatar
Mattbastard
Old 11-01-2017 | 04:38 PM
texashillcountry
Dirt don't hurt
Originally Posted by Mattbastard
Before he goes that far and if it isn't the cable the next thing to check is the speedo drive.
Old 11-02-2017 | 10:06 PM
b bop n bob's Avatar
b bop n bob
if you can't fix it with a hammer, you have an electrical problem
Hey Man (11-03-2017)
Old 11-03-2017 | 03:57 AM
Hey Man's Avatar
Hey Man
Well I discovered that the speedo drive wasn't working. The little tab was bent and twisted out of the slot in the rotor. I got it tapped back in and the cable is now spinning when the wheel goes around. I figure something happened in the speedo to cause the tab to come out of the slot and sure enough the collar in the speedo is sloppy and spins freely with no movement in the needle so I guess the speedo is toast.
Quick Reply: Signal lights don't self cancel anymore.
