Water and oil coming out breather
Old 10-22-2017, 03:05 PM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,361 Likes on 1,953 Posts
Default Water and oil coming out breather
My bike has developed a new problem.
It seems like after a decent ride a mixture of water and oil come out my breather (which is routed to the air) and I find a small patch of the mix on the ground the next day or so.
I looked in the oil bag and oil seems fine (no water mixed in) so I'm kinda baffled where the water is coming from.
Is that the umbrella valves???
'95 FLSTC
Old 10-22-2017, 04:01 PM
Beemervet's Avatar
Beemervet
Beemervet is offline
Been to Houston lately?
Old 10-22-2017, 04:37 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,854 Likes on 3,020 Posts
water pump / heater core
on the real side its the moisture that develops because of humidity in the top rocker boxes and that turns to milk and yes it spits it out < I am not going to say it
Old 10-22-2017, 04:59 PM
texashillcountry
Dirt don't hurt
Is there a fix?
If the humidity is getting in my rocker boxes does that mean air is getting in from somewhere?
FWIW there is no oil leaking out of my rocker boxes.
I only ask 'cause this is a new thing that hasn't happened before.
Old 10-22-2017, 05:03 PM
TriGeezer's Avatar
TriGeezer
TriGeezer is online now
Received 30,863 Likes on 11,600 Posts
My catch can catches a foamy mixture that looks like cafe mocha. So, it's water mixed with some oil.
Maybe your oil level is too high, causing more to come out the breather.
Old 10-22-2017, 06:27 PM
1997bagger's Avatar
1997bagger
1997bagger is offline
Received 1,788 Likes on 891 Posts
Why can't you be normal?
Pull the hose off from the head breather crossover and see if the foam is in the top of the hose, that will tell you if it is just in the bottom of the hose only and don't worry about it.
If those umbrella valves are messed up she will pump much oil out the hose and oil your bike
Old 10-22-2017, 06:34 PM
TSheff's Avatar
TSheff
TSheff is offline
Received 3,416 Likes on 1,584 Posts
When you say breather - from the rocker covers to the air filter or dripping from the air filter cover? I'd say condensation in Covers or filter cover.
Beemervet's Avatar
Beemervet
Old 10-22-2017, 06:47 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Originally Posted by texashillcountry
Is there a fix?
couple of things - if you have a plastic breather you should replace it as the plastic will and does chew the breathers hole up - my 1926 JD has its one and only breather valve in it as its metal
the foam is a normal part of owning one of these machines --------- or maybe its this
Old 10-22-2017, 06:59 PM
texashillcountry
Dirt don't hurt
Where's the fun in that?????????
Quick Reply: Water and oil coming out breather
