'89 FLHS fork springs....
Hi guys, my right fork seal stopped doing its job and let the fork oil out of captivity. For all I know, the springs in there are the originals and the ride would surely benefit some new, less bouncy suspension components.
I was going over the options available, and was wondering if any of you had installed this and what were your thoughts... I also plan do do the install myself after the season's over, although it will be a first for me, any tips will be welcome.
https://fortnine.ca/fr/progressive-s...-cartridge-kit
Oh....and will I need any special tools to get through this???
Thanks!
Thanks!
Your bike originally had air assisted forks, so if that has been removed it will explain why you find them bouncy. Air functions as a spring in it's own right and can be used to stiffen the ride. However there is no doubt that using a modern replacement should give you a significant improvement in ride quality. I have Ohlins fork cartridges in my 1990 FLHS, so can't comment on the Progressives, but they are most certainly worth a try.
qcbowhunter (09-13-2017)
Did you install them yourself? If so, anything I should know before trying it?
The hardest, messiest part is getting the oil in. Be patient and go slow, follow all instructions, as well as those in the FSM.
Thanks. Can't be worst than the pawl spring i did last year!
