push rod swap question
I am changing out the lifters and push rods on my ’97 flht. It currently has adjustable push rods, and I am replacing with factory non-adjustable push rods. To take the old push rods out, can I just adjust them slack and take them out, or do I need to have the motor at TDC of the compression stroke?
Also to put the new lifters and push rods in, is it mandatory to have the piston at TDC of the compression stroke, or can I just drop them in and install the rockers?
Received 4,361 Likes
You will need to have the piston in jug that you are working on (do them one at a time) at TDC or the rocker boxes won't seat correctly.
