Straight from the factory
08-05-2017, 07:10 AM
Putting s and s lifters in my Fxr, when I took front block off gasket is covering half of oil passage, dang!!!
08-05-2017, 07:42 AM
That's better!
08-05-2017, 07:54 AM
Mine was the same, although it's years since I last looked into it. It got your bike this far without mishap!
08-05-2017, 08:24 AM
Quote:
Originally Posted by
grbrown
I hear u, not gonna sweat it!!
08-05-2017, 08:35 AM
The only good thing about that would be the possibility of a little more oil to the crank..... Not a bad thing.....
There's a situation where alignment pins would not have let that happen.....
08-05-2017, 08:36 AM
I opened up the hole on my new gasket because they just didn't line up perfectly
08-05-2017, 08:40 AM
glidein wide
I bought the pins, the back cylinder was allined,
08-05-2017, 08:49 AM
I placed gasket on then screwed the four bolts in without the block and gasket wouldn't move around enough to have a wide open hole,so I opened it up.
Same goes for the block.
08-05-2017, 09:05 AM
I used a hole punch to "fix" my gaskets. Worked great for the following 100,000+ miles, until I sold it.
08-05-2017, 09:35 AM
glidein wide
Mine seem to line up with your test,I don't know why on gasket is up and one down. Cleaning blocks now, gonna make sure I have the gasket right. Thanks for the input.
