Evo BT Timing
Old 07-31-2017, 10:41 PM
Bobbed's Avatar
Bobbed
Bobbed is offline
Default Evo BT Timing
i picked up a custom bobber this summer that had a Harley evo BT engine in it. I know very little about the condition of the engine, up until this point it ran perfect. Cruising along one day started getting a mechanical failure, brought it home and found the lifter failed. Broke the guide block and ruined the cam.
So time to replace it all, I got the EV27 cam with some s&s lifters and adjustable pushrods. Cleaned everything and reinstalled it all.
I have the timing marks marks lined up correctly
with the pinion, breather and cam. However at this point of those components being lined up the motor is not at TDC anymore (I read that tdc doesn't matter?? True or false)
Well I finally have gotten it all back together, started the bike and only the rear cylinder is firing..? I messed with the timing plate trying to get it set but that front cylinder just isn't firing. I've checked for spark and it's there, fuel is good. Followed up with a compression test and was getting 100-120 on cylinders so we are okay there.
Is something not timed right when I had to replace the cam? Does the motor just have to be at TDC and the timing marks on the cam and breather lined up? Any advice, I'm so ready to get back on the road!
the picture shown is of the engine at TDC and the timing marks not lining up. When I originally installed it all the marks were all lined up (but not at TDC) am I having a brain fart, what's going on
Old 08-01-2017, 05:41 AM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is online now
Received 5,476 Likes on 3,650 Posts
When installing the cam the and lining up all the marks in the cam chest the piston "WILL NOT BE ON TDC".......
The only time you need TDC mark on the crank is when your setting your base timing... Do you have adjustable pushrods? And what ignition are you using?
Old 08-01-2017, 07:23 AM
Bobbed's Avatar
Bobbed
Bobbed is offline
Yea I've gotten a set of adjustable pushrods and still using the stock Harley ignition system.
Old 08-01-2017, 08:49 AM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,361 Likes on 1,953 Posts
I'm gonna show my ignorance and ask what an EVO BT engine is.
True
Kinda low IMO.
When I had stock pistons and an EV-27 cam I had 165 psi on both cylinders.
Do you have single fire or dual fire coils??
If dual fire switch the wires and see if the dead cylinder moves to the other side.
While you don't need the motor at TDC when installing cam you do need it at TDC when installing the bottom rockerboxes unless you are using adjustable pushrods.
Old 08-01-2017, 11:46 AM
Tom84FXST's Avatar
Tom84FXST
Tom84FXST is offline
Received 20,261 Likes on 5,864 Posts
https://rideapart.com/articles/brief-history-harley-davidsons-big-twins
you've seen it in print a thousand times
Old 08-01-2017, 11:47 AM
Bobbed's Avatar
Bobbed
Bobbed is offline
BT- Big Twin
The service manual in using states "if compression is 90 psi or above, and not more than 10% difference between cylinders, compression is considered normal".
i am using adjustable push rods, I'll have to try switching the wire to see if it follows
Old 08-01-2017, 11:53 AM
Tom84FXST's Avatar
Tom84FXST
Kinda low IMO.
What did you have 12.5 to 1 compression?
8>1 = 102.9 psi
8.5>1= 102.9 - 110.25 psi
9>1= 110.25 - 117.6 psi
9.5>1= 117.6 - 124.95 psi
10>1= 124.95 - 132.65 psi
10.5>1= 132.3 - 139.65 psi
11>1= 139.65 - 147 psi
11.5>1= 147 - 154.35 psi
12>1= 154.35 - 161.7 psi
I have never seen 165 on any motor I have checked the compression on...this chart is supposed to be close...my stock evo does about 110.
Old 08-01-2017, 12:12 PM
0maha's Avatar
0maha
0maha is offline
Received 4,679 Likes on 1,665 Posts
I was wondering what a "BT" engine is also.
Ditto on the TDC not mattering on the cam gear install. Cam gear to pinion gear, then breather to cam gear and you're set.
Old 08-01-2017, 12:13 PM
0maha's Avatar
0maha
0maha is offline
8>1 = 102.9 psi
THANK YOU! I always read these huge numbers, but every stock Evo I've tested comes in at around 110/120 more or less.
Then everyone tells me "REBUILD THAT THING! COMP IS TOO LOW!!!"
And I'm all like WTF you talking about?!?
Old 08-01-2017, 12:38 PM
texashillcountry
Dirt don't hurt
8>1 = 102.9 psi
All I can tell you is what the guage read.
I had stock pistons with the EV-27 cam.
FWIW the bad boyz calculator isn't even close to that chart.
It told me that 10-1 pistons should be getting around 180.
Quick Reply: Evo BT Timing
