Front wheel install - abnormal?
Old 07-06-2017, 09:14 AM
Panheader's Avatar
Panheader
Panheader is offline
Default Front wheel install - abnormal?
I change my own tires and just put a new front on my new-to-me 1998 Road King, and while reinstalling the axle it looks like there is a good amount of space outboard of the right side spacer that would be pulled in - pulling in the forks to the spacer...I reviewed the parts diagrams and it doesn't look like I am missing anything (its the first time I took the wheel off since I bought this bike). Is this a normal part of reinstalling the front wheel? It seems like there would be a good amount of tension pulling the forks in and I have not seen that much space on my 93 heritage softail or any of the sportbikes I have changed tires on.
Old 07-06-2017, 10:36 AM
Ruggs59's Avatar
Ruggs59
Ruggs59 is offline
That's pretty close to normal. With the axle nut tight on the other side then you put a (I use a drill bit) in the hole on the end of the axle shaft in your picture and pull the fork tube to it and tighten the two nuts to hold it there.
Old 07-06-2017, 10:38 AM
Ruggs59's Avatar
Ruggs59
Ruggs59 is offline
Also those spacers are side specific. One is a fraction longer
Old 07-06-2017, 10:51 AM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,361 Likes on 1,953 Posts
Panheader yes that's normal.
Old 07-06-2017, 10:56 AM
Panheader's Avatar
Panheader
Thanks Fellas, I'll double check that they are on the correct side - I put em back where they were but maybe they were wrong to begin with.
Old 07-06-2017, 11:47 AM
texashillcountry
Dirt don't hurt
Ride the bike and take your hands off the handle bars.
If it tracks straight then you're good if not then switch the spacers and try again.
Old 07-06-2017, 12:07 PM
Architect's Avatar
Architect
Architect is offline
Received 5,451 Likes on 2,779 Posts
Buy a shop manual!!!!!!! Especially when the bike is old, you are not the original Owner and as you stated maybe the parts were on wrong to begin with, good luck.
Old 07-06-2017, 12:35 PM
Uncle G.'s Avatar
Uncle G.
Uncle G. is offline
Received 3,768 Likes on 2,018 Posts
There is supposed to be a slight gap on the right side like that. The right fork leg clamps to the axle so there's no side loading on the fork sliders.
Old 07-06-2017, 01:06 PM
0maha's Avatar
0maha
0maha is offline
Received 4,679 Likes on 1,665 Posts
The spacer rests against a shoulder cut into the axle, not against the fork leg. The gap in the photo is correct.
And you very much don't want any "side to side" pre-load on the forks. Leave the lower fork clamp nuts finger tight (especially the right hand side), tighten the axle nut to torque, then tighten the fork clamp nuts. That way the axle can float side to side relative to the fork until it is set.
Old 07-06-2017, 01:26 PM
Ruggs59's Avatar
Ruggs59
Ruggs59 is offline
you will know if the spacers are on the wrong side as the brakes will be dragging.
Quick Reply: Front wheel install - abnormal?
