Cam in the bike id?
Old 07-04-2017 | 08:54 AM
IRON1250's Avatar
IRON1250
Default Cam in the bike id?
How hard is it to open her up and see if I have an after market cam? The previous owner did a lot of work and I'm not sure if it involved engine upgrades. Not sure if the cams could be identified installed?
Old 07-04-2017 | 11:25 AM
daven9113's Avatar
daven9113
It's not too difficult to check. Is the nose cone cover plate factory riveted in still? This is a common sign that it has not been messed with, most of the time. Not saying that someone couldn't rivet the plate back on.
Checking what cam you have is easier, if you have adjustable PRs. You would adjust the PRs take the pressure off the cam, and then it's a few steps away from pulling your cam cover.
You would have to pull your front exhaust and possibly your right foot board, going off your pic. Once that's done, then you can loosen the Allen bolts on the nose cone. Gently tap the nose cone and get it off. Do not pry with a screwdriver. They come off easier with a puller, and you don't risk damaging the nose cone or case mating surfaces. Can find them cheap on eBay.
Old 07-05-2017 | 10:13 AM
IRON1250's Avatar
IRON1250
The push rod tubes are two piece if that indicates adjustable.
Old 07-05-2017 | 10:57 AM
98hotrodfatboy's Avatar
98hotrodfatboy
If it's a 91 Evo it would have the stock L grind cam which was better than the Next grind cam... More lift and duration. Lift at the valve was .495". Lift at the lifter would be .3046". Pop a pushrod tube and get a dial indicator. Both intake and exhaust should be the same..
Or you can pull the cam. Not hard just Make sure you get a manual. Do you have adjustable pushrods?
Old 07-05-2017 | 11:42 AM
daven9113's Avatar
daven9113
Yes, it does. Checking will be easier now. Hope you find something good. Let us know.
Old 07-05-2017 | 01:17 PM
98hotrodfatboy
No it doesn't.. They're all 2 piece...
Old 07-05-2017 | 03:05 PM
0maha's Avatar
0maha
Yep.
Pretty good "quick and easy" test:
- Verify that the "V2" timing cover is riveted on (as mentioned above)
- Pop the retainer thingy off of one of the pushrod tubes then pull the tube up from the bottom.
If you have a riveted cover and solid pushrods, it's all but certain you have the stock cam.
No matter what the timing cover looks like, if you have adjustable pushrods, it's all but certain you have an aftermarket cam, but it's anyone's guess which one.
Old 07-05-2017 | 05:11 PM
daven9113's Avatar
daven9113
I might have read Iron1250's comment too quickly. All push rod have upper and lower cover.
Once you pop the upper cover off, then you can slide the lower cover up to expose the PRs. Clothpin holding up the lower cover.
Adjustable PRs would have a locking nut (see pic). Non-adjustable rod will be smooth. No way you can mix them up. However, this still doesn't tell you if you have a stock cam. The PO might have chosen to re-use the stock PRs with a new cam installed. Let us know what you find.
Old 07-06-2017 | 04:27 AM
grbrown's Avatar
grbrown
Thumbs up
That is what I did when installing my EV27.
Old 07-06-2017 | 02:42 PM
Yamaharley's Avatar
Yamaharley
Do you have a tach on the bike? Where does the power really take off and when does it fall on it's face? Mine picks up hard around 3 and quits at 5500. Pretty sure mines a stock cam.
Quick Reply: Cam in the bike id?
