Dash Lights
Old 06-30-2017, 11:18 AM
RANGER73's Avatar
RANGER73
RANGER73 is offline
Received 6,343 Likes on 3,187 Posts
Originally Posted by Uncle G.
Depends on what the base on your lamps look like. I used these for my Softail:
https://www.superbrightleds.com/more...ic-car-bulb/4/
These will work if you have the size BA9 round bayonet lamp base. This website has wedge base type lamps as well if you need them.
That's what I used and where I got them. My only issue was there base is a little small, so I put some foil tape high around the base near the glass to keep them snug. The pins on the side of the base are what make the connection the ground.
Old 06-30-2017, 01:52 PM
Uncle G.'s Avatar
Uncle G.
Uncle G. is offline
Received 3,770 Likes on 2,020 Posts
I also found them a little wobbly in the sockets (as were the original bulbs). I used some o-rings placed around the bases to center the bulbs in the sockets
Big_Dave88
12-13-2018 06:56 PM
nickybandy
01-17-2013 07:19 PM
Len
07-23-2010 06:55 PM
clucker
01-06-2010 06:45 PM
Taterdog
07-24-2008 10:54 PM
Quick Reply: Dash Lights
