Primary oil transferring to oil tank
My 1989 FLSH oil tank get fill by the primary oil , I did change oil seal, put heat resistance RTV on shaft and gear and lately replace my alternator ( from Axell to Compufire ) and the situation did get worst? Any idea where to look? Engine crankcase should be pressurized.
Thank
300sd1982@gmail.com
Claude
Thank
300sd1982@gmail.com
Claude
OP,
Are you putting to much in the primary?
Wow Tom..... That one took a hard hit....
Thank
300sd1982@gmail.com
Claude
Thank
300sd1982@gmail.com
Claude
How much fluid did you put in your primary? How much fluid did you put in your engine? How many miles did it take for this to happen?
Did you replace the crankcase oil seal correctly? Did the spacer have groove marks on it where the seal lips sit?
OK, so you put some RTV on the crank splines. What "gear" are you talking about?
Did you loctite your two small screws that was mentioned above?
You have an 89 case, check for a loose case insert?
You got to start eliminating some of these things, or you won't get to the bottom of it. Good luck.
