Pushrod question
Old 06-06-2017 | 05:23 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Not sure about the magnets.. But that's the cam and the seal. Behind the seal is the bushing.... You won't know if it's a stock cam till you get it out and post some more pics.....
Old 06-06-2017 | 06:05 AM
Durham man's Avatar
Durham man
Will do
Old 06-06-2017 | 06:10 AM
Durham man's Avatar
Durham man
Can I take cam cone off and leave cam and lifter in till I get mags
Old 06-06-2017 | 06:18 AM
98hotrodfatboy
You can, just make sure the front cylinder is at TDC.... It takes most of the tension off of the cam except for the rear exhaust valve. Or you can cut the oem pushrods and not worry about it....
Old 06-06-2017 | 06:28 AM
Durham man's Avatar
Durham man
Push rods are out
Old 06-06-2017 | 07:30 AM
Durham man's Avatar
Durham man
Looks good so far
Old 06-06-2017 | 07:31 AM
Durham man's Avatar
Durham man
Old 06-06-2017 | 09:02 AM
98hotrodfatboy
See that orange spacer that's the shim for your breather gear... Don't loose it.... Put it back on the breather....
Old 06-06-2017 | 11:34 AM
Durham man's Avatar
Durham man
Torrington bearing,stock cam
Old 06-06-2017 | 11:35 AM
Durham man's Avatar
Durham man
Quick Reply: Pushrod question
