no start panhead
05-31-2017 | 08:15 PM
no start panhead
i have a panhead, linkert carb, joe hunt magnito. timing is good, magnito brand new, new plug wires, new non res plugs. rebuilt the carb. all it does is back pop thru pipes and carb, adj. push rods all good..
05-31-2017 | 08:21 PM
You may get some good info here, but I'd post this in the pan head section. Those guys will get you on track
05-31-2017 | 08:30 PM
You're way off on your timing if everything is setup correctly.
Are you running hydraulic or solid lifters?
Who adjusted the pushrods?
How's your gap on the plugs?
Not too hard once you got spark, air and fuel.
Good luck!
Tom
06-01-2017 | 09:00 AM
Yeah, sounds like timing to me also. Got: Spark, Compression, Timing, Gas? You're missing one if it won't start. Oh, and giant butt and thigh muscles.
06-01-2017 | 09:54 AM
Make sure you retard it before turning on the ignition unless it is an auto-advance magneto. Then make sure it is actually retarding the spark when trying to kick it.
Griz
radio915
Shovelhead
13
05-27-2016 10:32 AM
grahamzies
07-09-2015 02:03 PM
Cory81
11-04-2013 07:51 PM
dr_ransom
Shovelhead
03-06-2013 01:17 AM
jgibson79
06-18-2011 11:08 PM
