Trans shifting problem
06-15-2017 | 07:07 PM
The last few were hard to get out in mine also ... clean it out real good and you shouldn't have a problem ...
06-15-2017 | 07:39 PM
It's going to take a lot more wear than just some witness marks to cause you a problem
06-16-2017 | 09:02 AM
found it!
pulled the clutch plates last night and the spring plate was missing half the rivets just as suggested. thanks guys
any suggestions on which kit to buy
The spring plate gives you a wider friction zone on the clutch lever than running straight plates and steels.
That said if mine ever goes out I will not be replacing it either.
Slammed-N-Senseless
EVO
16
11-05-2013 11:51 PM
LX HEMI
04-18-2012 06:53 PM
Medicfrost
08-31-2009 12:06 PM
choptop
EVO
07-12-2009 05:33 PM
mankx
08-11-2008 12:34 PM
