Trans shifting problem
Old 06-14-2017 | 08:27 AM
scg's Avatar
scg
Ok What am I looking for?
just to reiterate I have never had gears grind and no problems getting neutral. I pull the clutch in to shift into 3rd and and the shift lever just doesn't what to move
  #32
Old 06-14-2017 | 08:38 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Loose, damaged, or missing rivets.
Not saying that it's your problem just that it's easy to check.
  #33
Old 06-14-2017 | 08:50 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Your gonna need to pull the top cover and visualize if the drum and shift forks are ok... Sounds like a shift fork is bent or possibly 3rd gear is not sliding on the shaft..
  #34
Old 06-14-2017 | 10:52 AM
timsmcm's Avatar
timsmcm
You might want to get a small piece of window glass and check to see if your clutch pack plates are warped. Just one warped plate can cause this problem. The glass plate is the cheapest flat surface you can find. The thicker the better for a tool.
  #35
Old 06-14-2017 | 11:15 AM
scg's Avatar
scg
I'm at work now but if I remember right the SM says I need a special tool when removing the clutches. Can I get by with out it
  #36
Old 06-14-2017 | 01:31 PM
FreedomRider's Avatar
FreedomRider
You do need a special tool ... however, if you Google Harley Clutch Compression Tool you will find several results including how to make your own ...
  #37
Old 06-15-2017 | 03:44 AM
scg's Avatar
scg
found it!
pulled the clutch plates last night and the spring plate was missing half the rivets just as suggested. thanks guys
any suggestions on which kit to buy
  #38
Old 06-15-2017 | 06:04 AM
grbrown's Avatar
grbrown
Barnett Extra Plate kevlar set, which does away with the spring plate. I never did understand what purpose that served.
  #39
Old 06-15-2017 | 06:34 AM
FreedomRider
Once you get this all back together you will need to go through the entire clutch adjustment process ... once you have the clutch and cable adjusted you can use the cable adjuster to get the grab point where you want it ...
making the cable longer will move the grab point away from the grip ... making the cable shorter will move the grab point toward the grip ...
glad you found the problem ...
  #40
Old 06-15-2017 | 05:39 PM
scg's Avatar
scg
ok I have ordered the Barnett clutch mentioned on the previous post. I had a bitch of a time getting the last several plates out. Only thing i can see
that might be causing this is a slight grove in the clutch basket where the spring plate was. Hope this isn't going to cause problems with the new clutch???
Quick Reply: Trans shifting problem
