Softail Oil tank drain tube
Does anyone know if there is a tank replacement option to get rid of the rubber drain tube? I just out in an air suspension and I would like to get the hose to of the out of the way but don't want to add a bunch of fittings. Is there a tank that has been engineered to "fix" or relocate the drain?? OR if there are any ideas to reroute safely with a longer hose? I fear it leaking at some point though.
THANKS!
THANKS!
