First ride, not all is well. 85 fxsb
05-06-2017 | 03:54 PM
Quote:
Originally Posted by
R.N.CUMMINS
I can hear the solenoid make noise, like it moves the plunger. Starter does nothing. I trivial I'll just leave it and kick the thing till winter. Looks like a pain to do it all.
That's like next week for y'all up there ain't it???
05-06-2017 | 05:51 PM
R.N.CUMMINS
Battery was 12.45 resting, jumped to 3.25 holding the start button. Release start and back up to 12.45.
R.N.CUMMINS
Battery didn't do anything.
What next, a starter?
Stop buying parts...
Systematic troubleshooting is the only good way to isolate the problem and fix it.
Where are you measuring the voltage when you crank the starter, at the battery posts, or at the battery cable terminals?
05-06-2017 | 06:26 PM
Have you checked the voltage at the starter itself when it won't turn? Have you tried tapping the starter when it won't turn?
05-07-2017 | 09:27 AM
R.N.CUMMINS
I had cleaned the solenoid connections. Battery, cables and battery ground were all very clean.
Alot of folks will check as you have but seem to forget cking the end of the neg. cable at the motor/frame. There are times this connection is kinda hidden and not easily ck'd
WP
05-08-2017 | 06:28 PM
what wd50 said had to clean mine, once a few years ago and just put a new end on the batt. side this year cause the stock one was so weak.
05-08-2017 | 10:17 PM
raymint
what wd50 said
LMAO Well at least you didn't call me WD40
WP
Antnytro
01-06-2016 07:01 PM
fabfun
06-14-2015 10:55 PM
agove
03-06-2015 09:36 AM
2005sport
04-15-2009 09:50 PM
danzio
08-01-2007 08:33 AM
