EV13 cam: Use original gear or measure new one?
Still in the middle of this cam swap.
I didn't realize I needed .108" cam checking pins to measure the new gear (again, this is my first time doing this).
So, either I order pins and wait 'til they get here (the dealers don't carry them do they?) to measure the gears and see if they're the same...or just forget the new gear and go somewhere local to have them swap the gears out.
Any reason I should go one route or the other? Or is there another way to measure without the pins?
That said, unless there is obvious wear on your existing cam gear, the easiest thing to do would be to have someone swap it out.
Received 15,691 Likes
If you swap out the gear, you will be guaranteed of quiet operation.
If you don't, there is a possibility of having some gear whine.
Andrew's site also has information regarding color codes for sizing.
Bottom line, even if you had everything you need, swapping the gear would still be the better choice unless there is severe wear on the gear, in which case, the crank gear would be worn as well.
Are you doing this with the heads still on, or did you pull the heads?
rainsong (05-01-2017)
I found a machine shop near me that's gonna look at it in the morning and swap gears.
Cylinder heads? Rocker covers and lifter boxes are off but the heads are still on.
