Hydraulic clutch kit for 1988 fxst
Old 04-13-2017 | 04:37 AM
grbrown's Avatar
grbrown
Cool
Originally Posted by Dr.Hess
Dr.Linda likes her Amp power clutch thingie. I put it on her bike per Tup's suggestion.
That's me! I bought two of them, having discovered that AMP had been bought out and all their bike stuff has been discontinued. Got mine on US Ebay. A pal of mine has had one for many years. Apparently it took him a while to get used to it, but he's happy. One day Hyacinth will see the light of day once more and I can try mine.
As for the easy thingies, they all try different ways to do the same thing and all suffer from the same problem. They work fine on twincams, but not earlier Evos like mine. A post-1990 trans and clutch will not be better than an earlier set-up IMHO!
Old 04-13-2017 | 04:59 AM
Adam76's Avatar
Adam76
Originally Posted by grbrown
That's me! I bought two of them, having discovered that AMP had been bought out....
What? Don't they make/sell them any longer?
Aaaahhhrrhggg. I want to keep my Evo!!! Twin cams just aren't the same.
Old 04-13-2017 | 05:35 AM
grbrown's Avatar
grbrown
Wink
Unfortunately not. Do take a look around though, to see if anyone has them for sale.
Take a closer look at this item on Oz Ebay #272622077945 and see if it is sold for other Harley models. It looks as if it does a similar job.
At some time either late Evo or TC88 the trans was changed and given more clutch lift, which made those devices viable. In fact we bought a TC88 and the dealer offered one from day 1 when we bought the bike.
Old 04-14-2017 | 10:15 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
I bought an increased ramp plate for my bike around '09.
It's still there and I haven't burned out any clutches since.
I've got somewhere around 40k miles on it.
I wouldn't agree that they don't work on EVO's.
Old 04-14-2017 | 10:25 AM
texashillcountry
Dirt don't hurt
Adam if you do go with the shallow ramp system you need to alter how you adjust your clutch.
The book says to turn in until you hit the throwout bearing then back off 1/2 to 1 turn.
That's good for stock ramps but not so good for the shallow ramps.
If you use the shallow ramps you only back it back off by 1/8 to 1/4 turns.
Doing that will give you all the pull you need to properly actuate the clutch and it will be easier due to the shallow ramps.
At least it works for me...
Old 04-14-2017 | 12:20 PM
grbrown's Avatar
grbrown
Lightbulb
You're fortunate, however I did say:
Your bike does have a later spec tranny, introduced in 1995.
Old 04-14-2017 | 04:43 PM
texashillcountry
Dirt don't hurt
That later spec is because of the housing.
The ramps are the same back to '87.
Old 04-14-2017 | 06:32 PM
RedHogz's Avatar
RedHogz
I put an eze-pull on my Heritage 20k ago and wish I never did. No real benefit and a waste of cash.
SixDD
07-19-2019 07:56 AM
shankldu
10-01-2017 07:09 AM
Adam76
11
04-09-2017 05:52 PM
Drodrigueznyc
05-12-2016 08:16 AM
Lady Deluxe
07-01-2007 07:39 PM
Quick Reply: Hydraulic clutch kit for 1988 fxst
