1984 Harley FXRT Rear Wheel Assembly
I am putting the rear wheel of my 1984 Harley FXRT Sport Glide back together. It's been over 6 months since I took it apart so I don't recall exactly how it was put together. I'm relying on the exploded parts diagram but the order of the parts doesn't seem right to me.
It has the axle spacer, shims and wheel bearing spacer behind the sprocket and the bearing race, bearing and seal on the outside of the sprocket. That doesn't seem right...but it might be. See attached exploded diagram picture.
What seems to look right to me is to have the axle spacer behind the sprocket and then have the shims, bearing spacer, bearing race, bearing and seal on the outside of the sprocket. See the other picture.
Anyhow I just want to confirm what the correct way is before I put it all together. Thanks in advance for your help!
The Running Man
12-07-2012 06:10 AM
