Progressive 422's
Old 03-20-2017, 01:27 PM
Hey Man's Avatar
Hey Man
Hey Man is offline
Received 7,213 Likes on 2,887 Posts
Default Progressive 422's
Last week I installed a set of Progressive 422 shocks on my '93 FLSTC. The preload is set on the softest adjustment and the ride height is set at the same length as the stock shocks yet it feels like the back of the bike is a little higher now then it was with old shocks and the ride is a lot stiffer. I basically have two questions :
If I set the ride height adjustment so that the shock is longer, that lowers the rear of the bike, correct?
Also, is there some kind of break in for the shock where they will ride a little softer. I already have them adjusted as soft as they will go.
Old 03-20-2017, 02:44 PM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,361 Likes on 1,953 Posts
Yes the longer the shock the shorter the bike.
As for preload they should come set at the lowest setting from Progressive.
Old 03-20-2017, 04:30 PM
billib1954's Avatar
billib1954
billib1954 is offline
Since your old shocks were 25 years old, the new shocks should be stiffer. They will soften up with use in my experience.
Old 03-20-2017, 06:59 PM
Yamaharley's Avatar
Yamaharley
Yamaharley is offline
My experience with progressives is that they break in nicely around 500mi. I'm really light and actually had to turn up the preload.
Old 03-21-2017, 02:58 PM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,867 Likes on 2,429 Posts
Wink
500 miles for new shocks to bed in seems to be a widely applicable rule of thumb. Should only take a weekend.....
Old 03-21-2017, 03:22 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 5,467 Likes on 3,643 Posts
They are a lot stiffer than brand new oem's... I sent mine back cause I thought there was a problem with them, they were way to stiff and they said that there was nothing wrong. So I put them back in. Set them to the stock ride height and dealt with it till they got softer. It was good with my ol lady on the back but real stiff solo..... They are what I guess one would call a firm feel...
Old 03-21-2017, 09:00 PM
Sorg67's Avatar
Sorg67
Sorg67 is offline
I have about 250 miles on my 422s on a 92 FLSTC. They were extremely stiff when I first got them. They have softened some. A little more would be okay. But the bike handles a lot better. I also replaced the front springs. I really like the way it rides. But it is a firm ride.
Old 03-21-2017, 09:21 PM
Uncle G.'s Avatar
Uncle G.
Uncle G. is offline
Received 3,768 Likes on 2,018 Posts
I'm running 422s on my Softail and I think they're just fine for my 155 lb. weight.
Old 04-03-2018, 11:32 PM
Ensign Suder's Avatar
Ensign Suder
Ensign Suder is offline
1st Gear
Keep in mind that your old shocks weren't really doing what they were supposed to do - keep your rear tire on the road. Granted, they were a softer ride, but thats most likely because they were worn out. Ever see an old car with worn out shocks go down the road? They float and bounce. That was your bike. The ride will be somewhat stiffer than you're used to, but its what its supposed to be now. Handling should be markedly improved, and the bike will be much safer.
Old 04-03-2018, 11:51 PM
Prot's Avatar
Prot
Prot is online now
Received 15,811 Likes on 6,703 Posts
Look at the date of the last reply to this thread.
Quick Reply: Progressive 422's
