Oil in Carb. What gives?
Old 03-18-2017, 05:24 PM
RedHogz's Avatar
RedHogz
RedHogz is offline
I was gonna ask if your HD revved with a 'Winga-dinga-ding".....
Old 03-26-2017, 12:02 PM
Safety01's Avatar
Safety01
Safety01 is offline
LMAO. Two stroke did come to mind.
Old 03-27-2017, 09:11 AM
Uncle G.'s Avatar
Uncle G.
Uncle G. is offline
Received 3,764 Likes on 2,016 Posts
Originally Posted by Safety01
Thanks guys. Bought a length of 3/8 hose and vented to ground. After 100 miles I have no trace of oil anywhere on the engine. This explains why the bike was so damn dirty when I bought it. OH yeah, plugs look perfect too.
I'd still keep an eye on my oil level for a while. Even though you're routing the hose under the bike, the rubber breather valves in the rocker boxes can harden and cease to function properly with age and miles. If you are "using" oil, that's one place to look before tearing down the motor. IOW, rerouting the hose fixes the symptom, but not necessarily the cause.
Safety01 (03-27-2017)
Old 03-27-2017, 07:25 PM
Safety01's Avatar
Safety01
Safety01 is offline
Will do. Only has 6K miles but still 20 years old. Most gaskets and rubber are brittle and I am replacing them as we speak. Thanks for the info.
Old 03-27-2017, 08:14 PM
aquadave's Avatar
aquadave
aquadave is offline
Originally Posted by 0maha
Are you sure it's the carb drain tube and not the case breather?
Agree Probably the crankcase breather Especially since you said you're bring it back from the dead it's been sitting awhile so not unusual to puke oil
Old 03-28-2017, 02:18 PM
Uncle G.'s Avatar
Uncle G.
Uncle G. is offline
I mention this, because I had to replace the flapper valves in my motor back in '12. Suddenly, the breather started bathing the right side of the bike in oil. Since replacing them, I have virtually no oil carryover anymore.
pleasants9
02-27-2011 07:24 PM
36 hamon
01-28-2011 01:06 PM
PktChg
08-08-2010 05:24 PM
scoobasteve
Carburetor Related
04-05-2010 04:39 PM
pachowder
07-25-2009 06:36 PM
Quick Reply: Oil in Carb. What gives?
