Primary noise
Received 4,361 Likes
Like I said previously my tranny main bearing only made noise under power in 4th gear so I don't think that's your problem.
No other noises, runs/rides great. Going it apart. Hopefully no slop in the transmission shaft. Anything else I should look for that might point to a bad trans bearing?
You shouldn't have a worn shifter arm with only 15k on the clock. You sure someone didn't change the speedo head? THC is probably right about it not being the trans bearing, but....if you didn't change it and got her all back together and still had that whine, you'd prolly be tossing wrenches all over the garage.
so I pulled it all apart. Looked at the bearing on the inner primary, didn't see anything but it sounded kinda gritty. so I pulled the race, and the bearing and replaced it with the Baker one. Pulled the pulley off and checked out the transmission main bearing and it all seemed good. put it all back together, fire it up and take her for a ride, and the noise was still there. start looking around, and just so happen to feel the final drive belt and its seems way loose. tighten it up some and now the noise is gone. ride it around a bit, and now the belt feels like it has gotten even tighter. I also noticed another noise. I was pulling up to park the other day and killed the motor and while rolling there sounded like a knock noise ever so often could this be from a belt being too tight? also does it make a difference if you adjust the belt when the bike is warm vs when its cold?
was it easy to remove the Bearing from the inner Primary?
Have you use a hydraulic press?
Cause i have tha same problem:
I have a noise coming from my primary. While I'm riding I don't hear anything but when I let off the throttle I'm hearing a whistle sound. As soon as I pull in the clutch, the whistle noise goes away.
My FLHTC has 125.000 km (77650mls)
I wanna change the Beariing and Seals and use the parts from J&P
wich one is the better choice?
All ***** Inner Primary Bearing and Seal Kit
or
JIMS Primary Bearing Upgrade ?
Make it sense to change the Chain Tensioner to the
J&P Cycles® Automatic Chain Tensioner ?
Originally Posted by blumi
Hello,
or
or
http://www.allballsracing.com/harley...t/25-3102.html
blumi (04-05-2017)
