Fxr primary
Received 4,361 Likes
The tranny is a 1985 that had a tapered keyed shaft. I did a total rebuild to the tranny and swapped the tapered shaft to a splined shaft. I just wanted to make sure that I can use the same inner primary with the newer clutch basket and hub. Or do I need to use a 1990 inner primary.
TwiZted Biker (02-13-2017)
The ring gear on any splined tooth clutch won't mesh with any pre 89 starter...and there are different newer ring gears with 66, 84, and 102 teeth.
When ever you start changing primary stuff...it usually a "domino effect" and you need to use everything from the same range of years.
anything2wheels
05-03-2018 08:58 PM
