1988 FXRS sports
1988 FXRS sports
I'm looking at buying a 1988 FXRS. Can anyonedirect me to where I could find a copy of the specifiactions for this model with pictures of the bike and the accessories that came with it. Also does anyone know if this bike runs on unleaded withhaving to add anything to the fuel.
Thanks.
Thanks.
RE: 1988 FXRS sports
I can give you this:
Model: FXRS
Description: Low Rider
Productionyear: 1988
Engine: Evolution
Displacement: 1327 ccm (81,00 cui)
Horsepower: 67.00 (48.9) @ 5200
Torque: 114.00(11.6 / 83.9) @ 3600
Compression: 8.5:1
Bore/stroke: 89,0 x 109,0 mm (3,5 x 4,3 inch)
Valves pr cylinder: 2
Gears: 5
Final drive: Belt
Weight:
Weight dry: 261,1 kg (575,4 lbs)
Front tyre: MJ 90-19
Rear tyre: MT 90-16
Front brake: Single disc
Front brake diameter: 292 mm (11,5 inch)
Rear brake: Single disc
Rear brake diameter: 292 mm (11,5 inch)
Top speed: 160 km/h (99,9 mph)
Fuel capacity: 16,0 litres (4,20 gallons)
Reserve: 2,0 litres (0,40 gallons)
Fuel system: Carburettor
Starter ignition: Electronic
Seat height: 673 mm (26,5 inch)
Length: 2325 mm (91,6 inch)
Wheel base: 1602 mm (63,1 inch)
Ground clearance: 135 mm (5,3 inch)
Numbers produced: 3156
Price USD: 0
Price DK: 245000
Source: Bikez.com
Edit:That picture was just too big! deleted picture
Model: FXRS
Engine: Evolution
Compression: 8.5:1
Gears: 5
Final drive: Belt
Weight:
Rear tyre: MT 90-16
Price USD: 0
Price DK: 245000
Source: Bikez.com
Re:The specs that RudeDog listed:
The FXRS Sport models have higher ground clearance than what was listed, have dual front discbrakes, and haveair anti-dive front forks. The only threeFXR models that came set up like this were the FXRS Sport, the FXRS Convertible, and the FXRT.
du510
Motorcycles For Sale
13
07-01-2012 12:58 PM
