Bike stalls at night when I put turn signal on.
Old 10-14-2021 | 07:49 PM
mike131's Avatar
mike131
Originally Posted by chico4tuna
Not a bike, but this was the only forum I could find something about it. Its a 2005 honda metropolition scooter, and figured they're pretty similar makes minus engine displacement but same parts. The problem I'm having is it the high beam/horn/or blinker will kill the engine after I turn them on. The electric start will only work after I charge the battery overnight and for like 5 miles after full charges lights and blinkers will work until they seem to die out and kill my engine. after this happens it will only kick start and will run very rough and wont be able to go full throttle. Just wondering if the OP ever figured out the problem as his is basically the same as mine.
The scooter doesn't sound like its charging, so you need to make sure its putting out more than battery voltage which is 12.4 volts, when running not sure on your scooter but most 12volt systems will charge at around 13.8 volts, if you just have battery voltage, check the fuses, wiring, stator and voltage regulator, I would also have your battery tested, if you have been running round on just the battery there is a good chance thats bad also
manncat
04-18-2016 03:14 PM
lil-Lawler13
Electrical/Lighting/Alarm
06-10-2014 10:05 PM
Todd Householder
04-29-2012 08:54 PM
79lowrider
04-27-2010 09:01 AM
helstone
04-30-2007 03:50 AM
Quick Reply: Bike stalls at night when I put turn signal on.
