Strange turn signal problem
Old 02-16-2017 | 06:41 PM
14GuineaPig's Avatar
14GuineaPig
Is yours wired like this? In this diagram the turn signal, horn & brake light all work in the ACC position. They all are powered by an Orange/White wire off the Acc circuit breaker. A second O/W wire powers the speedometer backlights.
  #62
Old 02-16-2017 | 06:44 PM
Jackie Paper's Avatar
Jackie Paper
Originally Posted by texashillcountry
My bike doesn't have a fuse box.
It's got thermal breakers instead of fuses.
I just ordered a new harness.
They're cheap enough for my bikes.
So when I look at the 94 wire schematic and it shows your smaller fuses, they are fuse-able links or actual breakers? Is that what some one was referring to as reed switches? Or were the reed switch just a reference to the contacts in the ignition switch. However, I think the speedometer head was referred to for the reed switch.
Guinepig just answered my question..Have you checked voltage on both side of those breakers
  #63
Old 02-16-2017 | 07:30 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
That looks right..
I will confirm tomorrow afternoon.
  #64
Old 02-16-2017 | 07:32 PM
texashillcountry
Dirt don't hurt
Thermal breakers.
They throw if they get too hot and reset themselves when they cool off.
The reed switch is inside the speedometer.
  #65
Old 02-17-2017 | 02:41 PM
texashillcountry
Dirt don't hurt
Tentatively I'm gonna claim success!!!!!!!!!!!!
The PO wired in a Kuryakin module that turned the rear turn signals into brake lights.
As a last resort I bypassed the module and now everything seems to work fine!!!
  #66
Old 02-17-2017 | 03:12 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Cool, glad to hear T........
  #67
Old 02-17-2017 | 03:30 PM
Dr.Hess's Avatar
Dr.Hess
Ahh. Kury strikes again!
  #68
Old 02-17-2017 | 04:00 PM
Dan89FLSTC's Avatar
Dan89FLSTC
If we would have known the system had a lighting module in it we could have solved the issue by post #2...
  #69
Old 02-17-2017 | 04:51 PM
14GuineaPig
I hope you have it corrected. I'm crossed-eyed from looking at wiring diagrams.
  #70
Old 02-17-2017 | 04:55 PM
texashillcountry
Dirt don't hurt
Trust me you ain't the only one!!!!!!!!
I hope like hell it's fine but I ain't taking a test ride at 5 o'clock on a Friday!!
Quick Reply: Strange turn signal problem
