Strange turn signal problem
Old 02-13-2017 | 12:58 PM
Dr.Hess's Avatar
Dr.Hess
What's the actual voltage across the battery when the turn signals are not working? Is there any AC component to the charging system? That is, put your DVM on "AC" and measure across the battery. Next, with the meter back at DC volts, put red jammed in the back of the plug for pin 1 on that box and black at the battery negative. Read any voltage at idle (working)? Read any revved up (not working?)
Last resort: Doesn't Texas not require turn signals? Take the damn things off. Done.
  #42
Old 02-13-2017 | 01:45 PM
WP50's Avatar
WP50
Just for my curiosity and Pin 1 being the ground at the TSM
Something inducing voltage to the ckt???
WP
  #43
Old 02-13-2017 | 03:17 PM
Dr.Hess's Avatar
Dr.Hess
If the ground is bad, dirty, etc., then when you check for a voltage at pin 1 to the actual ground, you will get a reading. If the ground is good, you should get 0V.
  #44
Old 02-13-2017 | 04:20 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
The law in Texas is if the bike has them then they have to work.
I will figure this thing out even if I have to replace the entire wiring harness!!!
  #45
Old 02-13-2017 | 05:09 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Hey T, is there a way you can hook me up with a wiring schematic so I can look deeper into it. I don't mind helping but without a schematic it gets tough. And you canceler is different than mine so I'm sure the wiring is also....
  #46
Old 02-13-2017 | 05:17 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Are the other components that are on the accessory circuit working properly when the turn signals malfunction (horn, stop lamp)?
  #47
Old 02-13-2017 | 06:15 PM
texashillcountry
Dirt don't hurt
PROGRESS!!!!
While messing with the connector on the TSM I found that touching the wires under the ignition switch messed with the turn signals!!!!
I played with the wires some more and now the problem occurs all the time.
The turn signals are now putting out dot dot dash repeating with the bike off.
  #48
Old 02-13-2017 | 06:18 PM
texashillcountry
Dirt don't hurt
Will check again tomorrow.
  #49
Old 02-13-2017 | 06:19 PM
texashillcountry
Dirt don't hurt
In case I haven't said it thanks for all y'alls thoughts and ideas.
  #50
Old 02-13-2017 | 08:10 PM
Dr.Hess's Avatar
Dr.Hess
Originally Posted by texashillcountry
PROGRESS!!!!
It's talking to 'U'.
Quick Reply: Strange turn signal problem
