Question about wheel bearings
Just making sure I'm not going on the wrong path but is it normal for the wheel bearing to be loose? I took the front wheel off the bike for inspection since the pothole incident. I notice after taking the wheel off,the roller bearing can be push around in all direction inside the race. This has me concerned as I'm not sure if it suppose to be like that or it suppose to be a one sealed
Even when correctly installed and tightened up the wheels have a little bit of endplay. Many years ago I replaced my shovel front wheel bearings and visited a local auto parts shop, to ask if they had replacements. I didn't say what they were for. Yes of course we do, they are Ford front wheel outer bearings! Many autos use the same design with end float.
WildBill_50 (01-03-2017)
Received 4,361 Likes
End play range is 2 - 6 thousandths.
carl
