FXR with 113" S&S Motor
Old 01-01-2017 | 08:00 AM
grbrown's Avatar
grbrown
An alternative to consider, for reduced lever pressure, is the AIM VPC. Rather like the Rivera it uses centrifugal bob-weights to apply increased pressure at speed, while using a softer than stock clutch spring. I have one, but haven't installed it yet.
Old 01-01-2017 | 08:13 AM
feguy1's Avatar
feguy1
Makes me want to build another fxr.
Old 01-02-2017 | 01:59 PM
cwestfall's Avatar
cwestfall
pulled the primary today on the new donor bike and was somewhat surprised to find a Primo in there with a variable spring plate.
I think that the basket is also a Primo though I can't find anything in their catalog resembling this. If I had to guess this is a 94-97 setup judging by the 36 tooth basket. clutch pack looks like it will fit 90-97 oem harley clutch basket. I have the matching comp sprocket off this bike also (was not running a comp eliminator) so I am not worried about the primary ratio.
but here's the thing- the whole assembly is a lot taller than the stock setup. even with out the variable plate it sits a lot taller. I don't have my inner primary on yet because I'm still waiting on my trans sprocket so I cannot check the clearances. everything is in pristine shape.
Any thoughts? drag specialties states that this hub/variable plate will fit in the OEM primary. So I may have to end up pulling the hub and putting that in the OEM clutch basket. What do you guys think?
Old 01-12-2017 | 06:22 AM
nyokie's Avatar
nyokie
Believe it or not Im running the stock HD plus one clutch on my 121" with no problems
Old 01-12-2017 | 07:31 PM
1997bagger's Avatar
1997bagger
I'm running the Rivera set up, you only need a spacer that moves the Derby cover out and a inner and outer gasket
Old 01-12-2017 | 07:41 PM
TwiZted Biker's Avatar
TwiZted Biker
Your going to like that 113", that's a sweet spot for ***** and longevity on S&S motors. Compression releases recommended depending which cam it has.
thehuskybear
Classic HDF Photos
21
03-15-2024 11:18 PM
Daggett
Motorcycles For Sale
06-26-2018 09:04 AM
nevada72
06-12-2017 03:31 PM
atengnr
Shovelhead
11
01-24-2015 09:34 PM
Quick Reply: FXR with 113" S&S Motor
