97 FXSTS (Softtail Springer) - intermittent No Spark
Still Trying to figure this out. Believe me, you guys and gals are smarter then me so help a guy out.
No spark to plugs.
Starts great. Runs for about 5 minutes idling, then dies. No spark.
Lights are still working. so has power.
It does not putter like its loosing fuel. It instantly quits.
Let set for a few minutes (5-8 minutes) then has a spark and starts.
Rode it about 3 miles to a exercise facility and stay an hour. Came out, started, riding home it looses power for about 2-3 seconds as I coast along then takes off and I make it home. This is consistent each day.
Changed coil but still died.
Replaced the ignition module. no help.
Ideas please.
I've been told that a bad stator can cause this – any thoughts on that guys or gals.
No spark to plugs.
Ideas please.
Everything stock on rhis bike, other than the things you recently swapped out?
This is a carbed bike?
What ignition module did you install? What coil?
Other than the cutting out itself, why do you think this is spark related? What tests have you run?
If everything is OEM, my guess is ignition pickup inside the cone on the right side of the motor.
cooldriver
02-14-2015 07:06 AM
zenwarrior
05-19-2007 11:21 AM
