41mm Wide Glide vs 49mm Wide Glide
Scootertrash60 (10-08-2016)
Sorry for missing you guyses posts! Been a bit busy. Just thinking of trading the 41mm wide glide on my Low Rider build to a 49mm set-up. The project is moving along rather slowly, so I have time to think about these things. Better than thinking about it after it's done......
They are a much stiffer design, being made using significantly larger diameter tubes, which perversely enables them also to be lighter. The stock dampers inside them are not a lot to get excited about, which is a shame, however they will take fully adjustable 30mm Ohlins cartridges, which is enough to make anyone bounce for joy!
