95 FLSTN won't accept oil capacity
I just purchased the bike and performed an oil change with filter. I tipped the bike so as to get as much old oil out as possible. I also cleaned the in-line filter. The service manual says that with a new filter, the oil needed is 3 quarts. So, I blindly dumped 3 quarts in and found the oil came up to the oil tank neck! I know that there is always some residual oil left in an engine, but I've syringed out 16 ounces so far and the oil is still about 1/2" above the dipstick "full' mark. Any ideas on this?
Rick in Indiana
Rick in Indiana
Rick in Indiana
Rick in Indiana
Did the same thing the first time I changed the oil on my '91 Heritage. Now I start with a little more than 2 quarts, start it up and idle for a couple minutes. Shut it down and add enough oil to bring it to the bottom of the filler neck. About 2 1/2 quarts.
Don't forget to mention that the crank case does not have a drain plug and holds a half quart of dirty oil after being drained. Oil capacity in the book is based on a dry engine like after reassembling after a rebuild...
When I change my oil,I start the bike after adding the new oil WITHOUT the filter on it and wait until oil turns clean(1/2quart) ,turn off, install new filter, warm it up and top off to where you like it. I maintain my oil level at a 1/2 quart low all the time.
My '94 FLSTN holds about 2.75 quarts with a filter change. I always drain the oil hot, right after a run so the oil in the tank hasn't had time to seep back into the sump. Then I change the filter, add two quarts of oil then run the bike for a few minutes to circulate the oil and fill the oil filter. Then I top off the oil.
