Help, With Rocker Arm Bushing
Yep, they need to be reamed to fit. You install the bushings in the rocker arms then ream.
https://www.amazon.com/Jims-Rocker-A.../dp/B000GZQVI4
For ROCKOUT information & purchasing please click the LINKS below...
__________________
NO, they DON'T all do that!
Also on amazon.com...
I do have them for EVO engines, just not on my website. PM me for ordering details if interested.
Hackd (08-15-2016)
Just a thought....
You can buy the complete rocker arm from Boardtracker online for $39. By the time you buy the bushings & pay to have them reamed it might be worthwhile?
Also, make sure the machine shop knows what they're doing. The reamer needs to be piloted so the bushings get reamed in alignment. That's why there is a special reamer for the job.
I don't believe that Rocker Lockers are necessary for Evo's. I tried a set and could not even get them started if the bolt hole. I'm sending them to GlidenWide today...
As for the Rocker bushings, It's a rare occurrence that they wear out. Listen to Rockout, If your that worried about them just replace the entire rocker....
