Help, With Rocker Arm Bushing
I got tired of waiting for Harley to deliver the rocker bushings so I ordered the S&S rockers and put everything together yesterday. Haven't ridden it but around the block because of the rain, but it sounds like a new engine, no valve train noise finally. If the roads dry up before dark, I will take it for a short ride.
I think you made a wise choice
For ROCKOUT information & purchasing please click the LINKS below...
__________________
NO, they DON'T all do that!
Also on amazon.com...
Actually I didn't, with the new rocker shaft, I had to force them in the last inch or so I don't think I need them right away. I had the rocker lockers in before, and when I removed them they came out easy enough and in good enough condition to re-use, but when I tried to re-install them, I messed up the first one and not wanting to wait for a new set, I put it together without them, but, I will not hesitate to buy another set and install them in the future.
Actually I didn't, with the new rocker shaft, I had to force them in the last inch or so I think I need them right away. I had the rocker lockers in before, and when I removed them they came out easy enough and in good enough condition to re-use, but when I tried to re-install them, I messed up the first one and not wanting to wait for a new set, I put it together without them, but, I will not hesitate to buy another set and install them in the future.
The S&S rocker arm kit came with 4 rockers with the .75" bushings, reamed and ready to go, $237.00, S&S Cycle Standard Forged Rocker Arms 900-4119A Sold by: Murray's Custom Cycles, I bought the 4 new rocker arm shafts from Ronnie's Harley, $34.00.
timmay17
Engine Mechanical Topics
06-16-2014 12:22 PM
