Transmission shifter shaft seal
Question for you guys: can the transmission shifter shaft seal on a 96 Road King be changed without removing the primary cases?
I noticed my shift lever was loose and when I checked it out there is some oil seepage in that area. The shaft did not appear to move just the lever. I have to get a new bolt to use as the one in it is kind of ragged up. I'll try to add a couple of pictures.
Yes, requires removal of primary,
But i would suggest you clean that area very very well with a de-greaser.
After you clean it, go ahead and clean it again.
Then let it dry.
Then sprinkle some baby powder in the area to clarify if there is a leak overnight.
Unless it is a bad leak then it might not be worth the time unless you are changing a belt ,the transmission shift lever a stator or something else in the area.
The picture does not look like a leak but maybe it is a very mild seepage.
Then let it dry.
Man, I don't know if you can change the shifter shaft seal without taking off the inner primary. I would like to learn how that is done. Might save folks lots of grief.
I recently had to pull the inner primary and replaced several seals while it was off. One of them was the shifter shaft seal. I had to drill two small holes, screwed in 2 sheet metal screws and pulled the seal off. Then you have to seat the seal to a proper depth. I did this with the right sized socket, tapping it in slowly. Then you replace the washer, and new C-clip. Replace the shifter shaft and torqued the heck out of it with a new allen socket bolt.
I don't think I could have done that without the inner primary off.
Some pics of the work. 1. Pulling out the seal 2. Options for shifter shaft bolt. Went with the black one which was grade 8. Little to no play in shifter shaft now. 3. New C-clip (dark). Got a two pack at Lowes 5/16" diameter.
Good luck.
Good luck.
I stopped by the dealer on the way home from work and picked up a new bolt. I talked to one of the guys there about the seal and he confirmed it couldn't be done without removing the primary cases.
BUT I did get out of there today for $1.13 for that new grade 8 bolt and now the shift lever is tighter than a tick's *** on a hound dog!!
I'll clean the area up this weekend and see how much seepage is going on.
Thanks for the help!
As was said, be sure it's the seal. The shift adjuster screw and lock nut is right there, and mine tends to seep a bit of oil from the screw threads (and always has). Also, the vent for the transmission and primary is right above the shift lever area. That could also be a source of the oil you're seeing.
