Handlebar options advice ideas?
Old 07-10-2016 | 06:33 PM
CBCanada's Avatar
CBCanada
Default Handlebar options advice ideas?
Hey folks
My 1996 fatboy has black drag bars with zero rise that are on black risers. I am 6'1 and always find my arms are pointed down.
I am looking for about 2-3 inch rise in the bars and maybe 2 inch less pull back . I think this will give a neutral arms position with elbows bent.
Ideally I don't want to remove the risers. But I will if I have to.
What handle bar would you recommend?
If I get an oem fatboy bar and put on these riders will it work?
Here is my current set up
Old 07-10-2016 | 06:39 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Get you some chrome 1" risers and some chrome 16" handlebars and you will be a lot happier!!!
Old 07-10-2016 | 09:15 PM
langwilliams's Avatar
langwilliams
keep in mind your cables an brake line may be too short, your wiring for the switches too if you replace the bars. Look at those to see if there's some slack you can pull out or reroute them to get some room. those higher risers may look out of place with ape hanger style bars. the stock bars come back to you some an go up some. I'm short with a 34" shirt sleeve length an they work well for me but probably not for you. I like the look of the biltwell Frisco bars, looks like you can rotate them to bring them back or away from you to fit, an they'd look good with your risers:
https://www.biltwellinc.com/p43/buy/...-1-quot-black/
Old 07-10-2016 | 10:36 PM
Prot's Avatar
Prot
An inexpensive route would be to get some Heritage handlebars.
Old 07-11-2016 | 07:46 AM
Farm Shop's Avatar
Farm Shop
I swapped out my stock heritage bars for Beach bars. Love the look but the stock bars were by far way more comfortable.
And that way you probably wouldn't have to change cables and such.
Old 07-11-2016 | 04:13 PM
CBCanada's Avatar
CBCanada
Well I have lots of cable to spare so that won't be an issue.
Old 07-11-2016 | 04:39 PM
CBCanada's Avatar
CBCanada
Another issues is my risers are for 1 1/4" fat bars and most of the bars are 1". For example I like the sportster bars as could use those but they won't fit right? Unless I change risers
Old 07-11-2016 | 04:57 PM
langwilliams
you will need 1" risers for just about all stock hd bars. Someone near you may trade that is wanting to use 1.25" bars. you could look for wild ones chubby bars or others that an use those risers. you could also look for bars with built in risers.
Old 07-11-2016 | 05:33 PM
BigUglyMan's Avatar
BigUglyMan
Just to start you could loosen the bolts and give the bars a little rotation up. Might cure it a bit. But if that doesn't work, either find yourself some apes or swap out some taller risers.
Old 07-11-2016 | 07:41 PM
texashillcountry
Dirt don't hurt
Changing risers is really easy.
Quick Reply: Handlebar options advice ideas?
