99 Road King front wheel/tire upgrade question
I'm going to upgrade the wifes 99 Road King to an 18 x 3.5 HD Airstrike front wheel, Avon AV71 Cobra 130/70B18 front tire and brembos. I have all of the components except the tire and new brake lines.
Do I need the fender extenders to lift the fender a bit to install this wheel and tire?
My plan is to do this when she is gone for a couple of days helping a girlfriend after surgery, so I want to be sure to have everything on hand.
Well, I think I'm going to make a bushing for the clamp end and use a 3/4 inch bearing kit for the install. The speedo is electronic on her RK, so no need to worry about a speedo drive. I'll probably drill thru the bushing and into the large end of the axle under the clamp and install a set screw to prevent any movement, not that there would be any.
I've also heard of guys cutting the bushing so that when you tighten the clamp it compresses the bushing.
Thanks everybody for your input!
Fratdidit
Wheels/Tires
10-07-2014 01:56 AM
