Replacing the spokes in a spoked wheel.
I want to put new spokes on the front wheel of my 98 fxdl and was wondering if it would be possible to replace the spokes and nipples one at a time instead of taking them all out at once. I have never messed around with spoked wheels beforeand was trying to avoid making a mess of it. What do you guys think?
Check around with the Indys in your area.
Or, send it to the pros. http://www.buchananspokes.com/categories/labor.asp
Let a Pro do it
That's where I bought my spokes , to redo my front & back, rims.
Went with the Twisted Stainless. Top notch stuff.
I let my indy do it, because they need to be true & it is an art.
I think FSM calls for them to be within 1/32, runout & my indy trues his to within 1/64.
I'm sure Buchanan would do a great job, also.
They're price on labor is not bad either. Think I payed around $125 labor for each rim.
I ride a 1996 FXDL.
Ride Safe,
Harold
You can replace spokes one at a time, rather R&T all at once. Loosen all spokes until 90% of tension is removed. Leave a little tension on each one. Then replace one for one. You will then have to tension and true the wheel.
Edit - r&r'ing one at time will necessitate bending spokes slightly to get them in/out. Not optimal.
I've only ever watched a wheel builder build a wheel from scratch, but can't imagine replacing only one or two, although I suppose that must be possible. I have also watched someone true a stock Sportster wheel which came in for a new tyre, but was out of true. Looks like a black art to me! Doesn't need a Harley dealer or indy, as wire spoked wheels are universal, so any competent local shop may have the right skills, certainly my local Yamaha dealer does.
Bicycle shops build and true wheels all the time. In my experience with both, truing a motorcycle wheel is MUCH easier than a bicycle wheel.
When I wanted to replace my rusted spokes back in '05, I couldn't find anyone to do it, so I did it myself. The factory service manual outlined the procedure and gave the offset specs from the rotor flange to the rim edge. I used a spare axle and built a truing stand from scrap lumber with a piece of a coat hanger and a c-clamp for a pointer. I was able to get the wheels within .015 runout. This was as good as the rims ran.
I've built two sets like this now. I'm riding on the second set I built now.
Received 49,807 Likes
