86 FLST suspension bolts
just had the front bolt on the suspension shock shear clean off…. lucky it didn't have me straight off as it was was hanging down facing the road surface. Anyone had this problem? is it a design weakness? I have ordered new bolts (not sure i want to risk the integrity of the others) The devil will trying to get the piece that's left in the farm out. Looks like the primary will have to come off to get to it. Joy.
Have 200,000 miles on my Softail and haven't had it happen yet (knock on wood). Fact is, any bolt can break given enough stress/time.
I do replace the bolts whenever I replace the shocks (on the fourth set now).
On the other hand, I HAVE had the left side lower tree pinch bold shear twice on me.
Received 4,361 Likes
If you don't you will break them too.
Take lots of pictures and keep us updated on your progress as I am very interested on how you get to the front ones.
Good call...if someone put 89-99 shocks on it...they will hit the transmission mounting plate bolts at full suspension travel.
I replaced the bolts on my 87 and texas is right, the replacements are just a tad longer than stock. I'm not sure if the two bolts would butt together on the inside or not. I do recall machining off the excess before I installed them. But as Texas has said, a washer would do the trick as well. I still have the factory bolts, so if you want to know the measurement, just let me know.
Thanks guys… The plan is to get back into it tomorrow as I now have the the new bolts. Primary had to come off to get the sheared bolt out of the frame. I'll check and see if they are the stock shocks… I don't remember but a very useful bit of info Farm Shop… something that may not be that apparent when they are fitted. If they are they would have 44K miles on them so would be due for replacement anyway I guess. Will give a run down of the full outcome when we are done.
Cheers
Cheers
So… it looks like there are later model shocks in there as the separate reservoirs are missing. Not sure where they would foul the frame though when in use? (Farm Shop)
Devil of a job getting to the two top bolts of the Inner Primary… looks like it would have been easier to have taken the oil tank off? Had to get that off to get a drill to sheared bolt.
All back together now although we will have to strip again as the inner primary seal is now leaking (dooh) we didn't have the gasket kit and needed to clear the bench….so we'll be back in there before the bike gets ridden anywhere!! Thanks for all the advise fellas.
