Dynatek S ignition
Dynatek S ignition
Got my new ignition and reading it over, only two wires, blue and white, says to go to coil. I thought maybe it would plug right in to the three wire Oem plug to module, instructions don't talk about swapping out this style ignition ONLY points swap. So I made a tech call and he explained to me.
The module and the voes gets eliminated and the white and blue wires from new go to new "5" ohm coil included along with the white power lead already there (12 v ). Centrifugal advance was purchased separately and replaces the tin cup screwed into the cam.
Install this weekend while it rains again, hope this will be a good thing I'm doing here for reliability and performance. If I don't notice any change at all I will be happy with not wondering when my 1985 ignition will say ,"that's it,I'm done, thirty years is enough".
Just need to time it perfectly and I'm sure all will be fine.
Received 15,793 Likes
I doubt very much there will be any difference at all in performance...Dyna-S, Factory Electronic, or even, Points...Only difference will really be the timing...controlled by the installer.
BTW That goes for Single Fire/Dual Fire as well...Matters not what folks Claim, Take it to the Dyno, or Dragstrip...Prove it.
aces&8s (05-07-2017)
Received 4,361 Likes
Not a Dyna-S don't...
Ever since I installed my Dynatek 200P my bike starts much easier.
As an experiment I put the stock ignition module back in and once again it was hard to start.
YMMV
Racepres (05-13-2016)
Apples and Tomatoes
I didn't bring up Performance...the OP did, and we have more Street Bikes at the Harley Drags than full on DragBikes anyway...these guys don't "Guess" tho.
If I was going away from OE electronic iggy, It would be with Dyna [Dynatek electronic, or Dyna 2000, not Dyna-S]...Not the "knock-off" either. But, the Dyna-S has served me well. Long as you Maintain the Mechanical advance...religiously. Matters not where it came from...it is Crap...Been thru lots of them. Very much the Downside of the Dyna-S or Points...
Dyna S is simple and very reliable.
Your advance curve is now mechanical, use the 35* advance mark and open the weights to static time to get started, then mark the plate and do *** and ears adjustment.
Valve float is now your rev limiter.
Be careful that the bolt head for the advance unit does not touch when you install the cover.
http://www.zippersperformance.com/me...ce-rivera.html
