Enclosed Belt Drive and Knock Questions
Hey all. I have an enclosed belt drive, I believe its a BDL. I get an occational knocking from the front of the primary and not sure what it is? What kind of maintenance do I need to be doing on the belt drive? I already replaced the belt last year, belt I took off was fine.
Reason its got the belt drive is the case cracked and PO put in an S&S bottom end and the belt drive. Whats the reason for using the belt drive instead of chain? Would it be a big deal for me to convert it back to chain? Like always thanks for any info guys.
No real maintenance on that bdl. But i would check the crank nut and the 3 bolts that keep the splined hub tight to the front pulley.. Also make sure your belt is not rubbing anywhere on the outer primary cover. Make sure you use red Loctite onboard bolts....
When you say the PO installed the bdl because of a cracked case usually that refers to the area of the case where the inner primary bolts on. there is a cast ring there that accepts a large o-ring to seal the inner primary to the case so you don't leak any primary fluid.
If that ring is cracked, missing broke or whatever you will not be able to install a chain primary... Till it's repaired.....
No, never did anything maintenance wise on the clutch pack. Easy enough to check the front pulley though... Just check to make sure that it's not belt slap.
I ended up taking the BDL primary off because I could not get the belt tight enough (too much slack) and it would actually flop so much in a up and down movement under 2600 rpm (just a lite tip in cruise in 5th gear) that it would send a terrible vibration throughout the entire bike... I even tried a Rivera Primo and wasn't happy with that one either, forget why. So I bought a Baker SBD primary and with some adjusting and time I got it to work great. A little pricey but works very well.
Yeah my belt is tight no problem there far as I know. Gonna pull the cover tomorrow night and check things out.
Thing is I do have noticeably more vibration then I used to but figure its because of added power from the new top end. Before rebuild I could see out my mirrors fairly clearly on the freeway but now they're pretty blurry.
