New Wiring Harness
Old 04-25-2016 | 02:57 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Default New Wiring Harness
Yesterday I started putting on a new wiring harness that I got from J&P (obsolete at HD) and right off the bat I found a problem.
The 3 twelve wire connectors that J&P used were the wrong ones!!!!!
Now came the fun of taking the pins out of the new and the old so that I could use the old connectors with the new harness.
88 pins and a lot of diagrams later everything except the oil light seems to work (broke the sending unit) even though I had to rewire one connector twice because I put the wires in backwards.
Damn things are keyed who knew?????????
The reason I did all this was that every time I had to strip some wire on the old harness it was very corroded up inside the jacket.
I didn't like that one bit!!!!!!!!!!
Found a broken bolt on disassembly so that's my next project.
Of course the damn bolt broke off inside the frame giving me nothing to get a hold of!!!!
Moco says it's supposed to be a grade 5 but I'm going back with an 8!!!!!!!!!!!
Oh well that's for another day when I get a better screw extractor set.
Old 04-25-2016 | 03:01 PM
flhchaz's Avatar
flhchaz
Man that's a lot of work!
Old 04-25-2016 | 03:16 PM
texashillcountry
Dirt don't hurt
And a major PITA without the right tools!!!
I had put off ordering the male pin connector tool because it's over $100.
I went ahead and ordered it because I don't ever want to work that hard getting a pin connector out again!
Old 04-25-2016 | 03:23 PM
0maha's Avatar
0maha
Nothing is easy.
Makes me think of those videos that were going around a while back with the guy from Tatro Machine rebuilding an Evo. What I liked about those vids is that they showed all the mistakes, all the do-overs, all the false starts. Stood in sharp contrast to the highly-edited Norm Abrams type where he can build an entire dining room set out of cherry and be done in an hour.
Old 04-25-2016 | 03:24 PM
Beemervet's Avatar
Beemervet
WHAAAAT?
http://www.ebay.com/sch/i.html?_odkw...+tool&_sacat=0
Old 04-25-2016 | 03:32 PM
texashillcountry
Dirt don't hurt
Originally Posted by Beemervet
Those tools don't look right.
The connectors I have are AMP.
Old 04-25-2016 | 03:42 PM
texashillcountry
Dirt don't hurt
Old 04-25-2016 | 09:57 PM
Bumpandrun's Avatar
Bumpandrun
Those pins suck!!! That was a bunch of work u did!!! Lol not easy
Old 04-26-2016 | 05:56 AM
texashillcountry
Dirt don't hurt
Are they any easier with the right tool???
Old 04-26-2016 | 07:08 AM
johnjzjz's Avatar
johnjzjz
if you use only 14G black wire this time and do a late model FLHTCU with a side car you will never complain again about wiring
the tools help and they sent you the wrong harness BTW
Quick Reply: New Wiring Harness
