2007 swing arm 1997 electra glide
Got this swap done this winter looks like something is off. The space on the pulley side has a **** hair between the fender and tire the right (brake side) side has 1.1/2 inches.
It rides straight down the road no problems but was so close it Sheard off my L side blinker wiring.
The pulley is perfect in alignment. So I can't just shim the tire over . The brake caliper is also from a 2007 so it connects to the swing arm and the axle. With no wiggle room to shim over. It looks like it is mounted perfect. Any way the swing arm can go in favoring 1 side?
Received 4,361 Likes
His bike was just like what you are describing.
Everything cleared but it was tight as hell on the left side.
