Cam swap parts list
Here is my parts list. I went with fresh rings since the cylinders had minor scarring.
Andrews EV-13 cam $119.95
Dynojet Thunderslide with Jet Kit 8708 $128.42
Crane Cams Time Saver Adjustable Push Rods 4-0030 $126.72
Dynatek 2000P DD2000-HD2EP ignition module $145
Crane Cams big axle lifters 3-2050. set of four for $189.95
Crane Cams cam bearing 7-0400 $15.51
Cometic Cam Gasket Service Kit C9624F $19.04
Cometic EST Top End Gasket Kit w/.030" Head $87.39
Screaming Eagle Air Cleaner Kit (Carbureted Evo) 295433-99B $127.96
New set of stock rings
Milled Heads .025"
Milled Heads .025"
You can if you want but it's a wasted $100 IMO.
I had some adjustables in my bike and the damn lock nut came loose.
I pulled them back out and reinstalled solids when I rebuilt my motor.
Unless you are going with a radical cam there is no need for adjustables.
BTW I think you would like an EV 13 better in that big of a bike.
It's got more torque at the low end to get all that mass moving.
Listen to this man....it will save me going on a rant about adjustable pushrods...
or put down the adult beverages till your done. Lmao
Bikerscum
2014-2023 Touring Models
06-07-2015 09:53 PM
