Exhaust options
Exhaust options
This will be a surprise to those of you that know me... curious about cutting my drags to add a slip on to improve performance, if that is even possible. As I am quite happy with the sound and performance.
But people are firm that I am losing performance even with power cones installed. I currently own three systems and buying another is not an option at the moment.
Reason for consideration is not to burn out my new valve job or do any other damage to my rebuild. Drags are 1-3/4" ...
Options and opinions please....
If you are happy with the sound and performance of YOUR bike, the only option you have is say blow me. If you are having to drop gears with real world riding suffering then make a change. Just be careful with that Bumpandrun, he will have your bike down to frame designing a exhaust system.
Received 23,591 Likes
Power cones do help, I will not run drags without. So my question stands, any recommendations on a baffling to help things out or a slip on ?
What I would like to see is a before and after curve of adding a baffle inside my 1 3/4"pipes without cones, versus just cones.
Already seen curve with nothing at all. Is there such a link or a site to go to ?????
I gave my younger brother a hard time about the 2" Sampson drags on his FXWG for years. Finally convinced him to put baffles in. He noticed an immediate low end torque improvement. You might try baffles before cut your pipes, cost less than slip ons, keeps the drag pipe sound at lower volume, etc.
Another friend put 12" baffles in the 1 3/4" drags on his FXR, that bike is quieter than my FXD with stock looking Khrome Werks slip ons.
Received 4,361 Likes
That's cool, thanks, I seen those 4" ones but they didn't say what diameters, I'm going to buy and try those 1-3/4"x4" mini baffles and see if any different. Curious if I should try them with or without the cones, maybe I will try both ways. Main goal is to not damage my exhaust valves. Haven't gotten any feedback if a baffle will help prevent damage. My plugs always look good and pipes are not coloring from excessive heat so I think things are good. Just trying to make improvements here if possible.
I bought some 1 3/4" baffles that were in the Drag Specialties Catalog and they helped immensely.
If I recall they were like 12 or 14 inches long.
